Box for BTL
shortyg83
Ok so I have an Fi BTL. And my car is a hyundai tiburon. The sub is 15 inches.
Right now it is in a box i built for my old 15 inch type R.
The box is not made of MDF it is made of particle board. The box is 2.83 cubes and it is tuned to about 34hz. I am Building a new box tonight which will be made out of mdf, dimensions will be height=16.5 width=36 depth=15.5 with a 3 inch port and tned to 34hz. it will give me 3.56cubes. Do you think I will notice an actual differnce in sound from this?
alright.
I would see if you could fit a 3.75" wide slot port.
You should definately see a gain, as the btl will need much more port area and a much stronger box than the type-r.
I would consider doing a double baffle.
the bl's sound goood in moe lester's plans from here 3@35 the Btl is in a box belunt from here built 4 a@ low to mid 30's from what he tells me. It gets loud just not loud enuff for me although it was also at 1ohm at the time on a 20.1. Hope this give you some ideas
Ok so ive been trying to get a lil more space but all I have is
16.5 deep 16.5high and 36 wide
I tried changin a bit but still the most i am coming out with is
3.5 inch wide slot port going back and a ben with 12 more inches of port. 33hz tuning. 3.563 cubes or this
3 inch wide port bend 7 more inches and 3.833 cubes.
shortyg83
shortyg83
pa
shortyg83
