Box for 6 12 inch RF HX2's in 2000 Explorer Sport
gumby688
Start of build for 6 12inch RF hx2 subs 13.3 cubes tuned at 34hz will run them with a Popcorn Sounds 4k. Optima yellow top under hood and 2 75ah C&D in the back with a 240 amp American Armature alternator. 2 runs each 0 gauge Audio Technix wire and 0 gauge big 3 upgrade.
Using 3/8th threaded rod for bracing
Will be 13.3 cubes after port and speaker displacement
using 6 braces altogether the threaded rod is so much easier than wooden bracing and takes up way less air space.
Well thats what I got done today wil post more pics as I take them
Ports and speaker openings cut out today
Using 4 4 inch diameter PSP dimpled aeroports 6 inches long tunes 13.4 cu ft to 35.5 hz
Internal view showing bracing and ends of aeroports
That's sick and 6 of those subs man I'd love to hear that I used to have a couple of them that were blown I wanted to get made custom hefty as hell I ended up selling them though.
Box looks sick too.
4 of them @ 6 inches tunes me @ 35.5 hz and I have 0 port noise super clean sounding . Now need to get my cam back from friend who borrowed it so I can take some more pics and show box installed and wired up then rip it out and paint or cover the box for perm install. Have a test video
HERE but cam has ****** mic.
Great choice of subs, but why the 4" ports? I'd expect a port noise and compression. I'd go with three 6" aeros instead if I were you...
Other reason I didnt go with 6 inch is I already had the 4 inch from previous and you can't get the 6in in dimpled
gumby688
gumby688
Fryeburg,ME
gumby688
