Box For 2 XT212s
Fate710
I'm needing a box made and was wondering if anyone has ever made a box for a set of Crossfire Audio subs.
Here are the specs:
Mounting Depth (in/mm): 7.125/181
Cutout Diameter (in/mm): 11/279
Woofer Outer Diameter (in/mm): 12.5/318
Woofer Displacement (cu.ft./ltr): .15/4.25
Impedance: Dual 1.8 ohm
Nominal Power Handling (RMS): 1000 watts
Maximum Power Handling (PE): 1500 watts
Dynamic Power Handling: 3000 watts
Voice Coil Size: 3" 4-Layer all aluminum
Magnet Weight: 240 oz.
Frequency Response: 25-250Hz
Resonant Frequency (fs): 31.72Hz
Qts: .4262
Qms: 4.822
Qes: .4675
VAS (cu. ft./ltr): .972/27.54
Efficiency (2.83V/1M): 84.579
Optimum Vented Volume
Internal Volume: 3.15cu.ft/89.2ltr
Tuning Frequency: 32Hz
Port (Area x L) 25 sq. in. x 18 in.
-3dB response: 32Hz
Maximum Power Handling: 1500 watts
If anyone could help that would be great
i dont think he was asking to pay someone to design a box for them. he asked for help in designing/learning his own box.
start by posting what you want your box tuned to, and the space you have available in your car. Heres the rule of thumb when choosing your tuning frequency: 20-30 Hz for SQ (sound quality), 30-40 for SQL (balance of SQ and SPL, and 40+ for SPL (generally only used for competition boxes). Also post how many watts you wil be feeding the sub. When under powering subs, it can usually be a good idea to make the box sligthly larger than the recommeded volume.
well truthfully I was wondering if someone could custom build the box for me. If not then the plans would be fine. I will be feeding each sub 1000 watts @ 1 ohm. They are rated @ 1300. Will get some actual dimensions shortly
send Moe Lester a PM...he'll design/build it
Fate710
Fate710
Indianapolis, IN
psych0ticnemes1
