box design
[quote name='jersyn82']I need a box design for a fi btl neo n2 15". Can only have 16.5" tall and 32" length. Have 2 4" aeroport to use. Only going to be running 1500w. If you need anymore info please ask. Thanks[/QUOTE]
@Buck can help u if he's around..
How does 32Lx23Wx16.5H. With displacement and 2 4" aeroports at 8" long puts it right at 5.4cu. and 32hz. How does that sound
Its a catch 22... you want more volume to compensate for lack of power, but being neo, going over 5 cubes with only 2 aeros is going to make your rise absurd. Im talking like 1ohm nominal and 6 reactive.
What music do you listen to, and what are your primary goals?
Sound quality, just good tight bass. I'm wondering if I should just trade it or save for an alternator. I listen to a little of everything.
If sq is main concern, rise is irrelevant. It will still sound fine on 1500w.
Id worry that 5.4 would make it a little bottom heavy and boomy on the low end.
Are you looking for a flatter response?
I can definitely go smaller, 4 cu. would be perfect but everyone told me bigger is better pretty much
I ended up finding specs. Fi says 3-5cu on the 15. TS were pretty close to what i expected.
I'll stick with my previous rec of 4.25 @32 or 33
Thanks for the help... If boomsday doesn't get a hold of me by tomorrow I'll build to those specs
737
I've used that driver and the ported box is closer to about 2 cubes. We did 1 in a stuffed/sealed 1-1.25 cubic foot box, stuffed with 1 lb of...
890
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
4K
jersyn82
jersyn82
ohio
kr15
Decebal
    Jun 10, 2024
