box design help two 12s please
What's going guys I have a 07 Chevy monte carlo ss coupe and I need a box design for two 12s soundqubed HDS312 subs if someone can help me out with blueprints, Here's the measurements off the trunk 38 Length/ 35 width/ 18 height / tuning 35 or 34 I listen to a lot of hip hop,dubstep,techno Basically music with the bass basically music with good bass workers lol
Soundqubed has box specs under tech support on there web page. For 2 12's calls for 3.50^ft (4) 8" or (2) 12" or (1) 15" vent area 56.0 sq" vent x 20" long
Speaker Box Construction
A strong box is essential in a high output system. Your box should be free from air leaks and braced internally if the volume exceeds 2 cuft. Internal cross bracing is far more effective in making a rigid box than doubling the wood thickness. Doubling the wood thickness adds a great deal of weight to your vehicle, and the added wall stiffness is less than stiffness added by cross bracing. Try to cross the braces at the same point so that they add strength to each other.
The inside seams of the enclosure can be a source of air leaks and potential weakness if the joints are not cut perfectly. One way to strengthen these joints is to use gluing cleats on the inside seams.
Just copied hope this helps.
Repoman79
Repoman79
Nj
Bomber Z
vegang
vegang
