Box design for 2 sa-12’s or 15’s
Prestondrew40
Car audio enthusiast
70
Mobile
Looking for a design for 2 SA-12s or 15’s. Gonna order them Friday. Box parameters are 33w 24h 20w. Don’t have to be exactlly those measurements, can be a few inches bigger or smaller. I’m a broke high school student, so A free design would be better
Gonna need more info than what you provided dude. The dim numbers you provided are about 9 cubes gross. So might be limited on space for the 15's depending upon cubes required but the 12's are doable. @shredder2 might help if you buy him lunch.
download torres box calculator, play around till you find your airspace and tuning.
18933
Wdym by more info? I already talked to shredder and he said he would pass on this one
Simple. The designer will need vehicle they're going into, max measurements to work with, even tho you said it doesn't have to be the dims you provided already, power using, tuning choice, etc. W/o any of those, they won't work with ya. Get on FB car audio groups for some designers.
There’s more to it then choosing your air space and tuning. You need to be sure the port is the right dimensions and your air velocity is right for your power. My enclosure turned out to be over a cubic foot bigger than recommended since I like to tune high for my music style. If I would’ve just went with recommended air space with a higher tuning it would be peaky
2005 Tacoma, the dimensions are the max, i have plenty of room to play around with. Power will be a 3k taramps. Tuning doesn’t matter but no higher than 35hz.
I just bought a pair of SA's and a prefab box from Down4sound that's specifically built and tuned for the SA 12's
So I was wondering what would yall use to design your box. I just don't wanna do black carpet or black bedliner paint bc to me I want something...
391
I've used that driver and the ported box is closer to about 2 cubes. We did 1 in a stuffed/sealed 1-1.25 cubic foot box, stuffed with 1 lb of...
562
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
Prestondrew40
Prestondrew40
Mobile
IndySlim
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
