Box Builders Need Plans Box Have $ in Paypal...
Lckmyblls
4 Combat Tours & Counting
I need plans for a high tuned Fart box i just built a daily driver box 4 cubes @32hz but now i need some plane for a box tuned to 60hz for spl. If intersted leave message here or pm me. I have all the measurements ect.....
Edit: Cant get the title right Plans Box FTW....
2 12" Db Drive Platinums Dimensions: no taller than 14.5" no longer than 36.5" long and 18.5" deep
I want the subs on one side and the port on the other its going in my wifes grand am going to face them foward with port on drivers side and subs on the mic with the most port area possible....
Here are the specs:
FS 25hz
Qts .63
Qms 8.41
Qes .68
Vas 1.03 cubic ft
Xmax .79 in, 19.1mm
Re 6.7
Pe 1500
Le 5.8 mH
SPL 89db
RMS 750 / Peak 1500
are you sure you want it tuned that high? i'd think a grand am would peak lower than that (and why would your wife want an SPL box?).
anyways, i did the best i could with those dimensions:
http://www.subwoofertools.com/forum/ported-box.asp?Ew=36.5&Eh=14.5&Dia=6&Xmax=13&Vd=.1&NumW=2&Vb=3.8&Fb=60&Qts=&Vas=&Fs=&CE=0
make the port any bigger than that and it doesn't work (and the site changes the box dimensions for you). hopefully 84.5 sq in of port is enough.
o ya didnt even notice that i was half asleep earlier... 60hz is hella high like you wont have much response at all below like 45hz... im not sure about those subs but id prolly go more around 45-50 if its just for burpin.. and possibly a little more volume
I have a feeling that he hasn't spent too much time with sweeps //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
It peaks at 60 to 64 hz there was no diff. inbetween there (or very little) this is just a second car im going to compete with towards the end of the season i ran through in a clinic before the show and played around with it and hit a 147 with box facing back...now i know ill gain if i flip the box subs on pass side and port on drivers i seen another grand am do a 152.7 like that but i deff. need to tune higher and foward fire the subs...now that might change the peak freq.? im not sure....
Lckmyblls
Lckmyblls
Fort Campbell Ky.
Lckmyblls
