Gearstix
I will eventually be building a box for my two Mach 5 SPL-12s in a blowthrough.
I've never built a box before. I'm not sure what thickness of MDF I will use, or if I will use MDF. It'll be 3/4" or 1" I'm guessing.
I know at Rona I couldn't get 1" MDF, only 3/4" and it was about $38 a sheet I think.
So, keeping the fact in mind that I've never built a box, what would be the most straightforward, and bulletproof ways to build one? I see some of you guys do not use screws at all.
I'm not sure if I want to spend the time pre-drilling every hole. Can I use self tapping screws?
My box will be double baffle I'm pretty sure.
What do you guys use to seal the box up inside? Silicone? Glue?
What about covering the box? My box will be in a blowthrough but I have a fiberglass camper shell to cover my bed. I'm liking the Fleckstone stuff, is there any preperations you need to do to MDF to apply it?
Do you have to spray on some sort of sealer to the MDF when the box is done?
I haven't decided on any box plans yet.
I have to pull the bed off and re-align it, and I don't have amps/batteries yet, so it won't be going in my truck for a while. But If I figure out the cut out diemensions, I could build the box.
I'm also looking for any information that will help me.
My dad has some tools I can use to make the box.
Is there any other tools I will need?
- Router (not sure of any details)
- Table Saw
- Compound Mitre Saw w/laser
- Jig Saw
- Have some clamps
- Belt sanders I think
- Multiple power drills
- Measuring tools, squares, etc.
