Box Build Help (Aeroport)
Teezy
Ok, so i was looking to get the volume of my box i got 7.2 ft3 i wanted to know if it's right the box dimension are H/16 W/23.5 L/40.5 Im looking to make and internal aeroport box because of the limited space. I would also like to know the best port size and how many personally i was thinking a 8" port on 2 12's then i was like with the aeroport i might can do 2 15's in the box and it sound's good well idk im more of a mechanic than a box builder i'm in need of help and your all the one's i trust.
Thank you.
I was trying to cover a good bit of space in my trunk a 4 cube box would be very small compared to the dimensions i have the cubes i calculated in my box i 8.8 cubes
not enough port area. try 2 6" aero's in 6 cubes net
Final question maybe lol.. What size obsidians and aero would you do with a 8.8 cube box matter fact can you tell if i got that right everyone says 2 cubes now your saying 6 that means smaller box right?
[quote name='Teezy']Final question maybe lol.. What size obsidians and aero would you do with a 8.8 cube box matter fact can you tell if i got that right everyone says 2 cubes now your saying 6 that means smaller box right?[/QUOTE]
2 15's between 5 and 7.5 after displacement.
As far as ports...
http://www.stereointegrity.com/images/Obsidian/Technical/Recommended Port Surface Areas.pdf
IMO it is worth the little money to get one of our fine pro box designers to do the work for you on a design, I prefer @Moble Enclosurs ;
Welcome to the Obsidian club, I think you will be pleased with your new subs!
Teezy
Teezy
Ellenwood, Ga
Teezy
vegang
vegang
