box build for rsxs1212
Port area is based upon the box size, not the sub //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif You're not even at 12^2 per cube which is the smallest I'd ever go...
No, you're very wrong. Both need to be very much considered but blindly basing port area on box size is just plain stupid. Just because that's what AQ/DD recommend for their subs does NOT mean it is the only factor to consider.
I had an enclosure that was about 5 cubes and had only 36in^2 of port. That's only 7.2" per cubic foot... oh noes it must sound like *** right?! It played flat from 25-80hz in room and the subs would run out of steam before there was any port noise.
I just want to let everyone know that this box rocks!! sounds amazing.. no noise whatsoever and the sub is hitting every note that i want it to so i am happy..
Thanks!!
mike **** good looking box bro, about the same size as my 15 box for my rd audio alpha, you saw it this past weekend anyway. i took home third with a 142.5 an climbing man on sunday so the box has more in it just have to find it.
i don't think this box or port was too small for this sub, how about you guys save yourself some trunk space build small for a change tune higher than 34hz for peaks sake an then tell me what you think, cause 3 cubes on a pair of 10's is just crazy i think. i have put 10's in the same size box as mike has done for this 12.
Thanks!!
Glad to hear that you are enjoying your new box. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Mike465
Ami Creations
Mike465
Kennesaw, GA
Mike465
