Box build for Brandon
Mike465
Ami Creations
Ok everyone this box is for Brandon's 2 12" DC Audio Level 3's.
Box is 3.0 cubic feet after displacement with 43 square inches of port tuned to 35Hz.
Ami where do you go for your MDF? Know a place with bulk deals or just pay per sheet?
Well right now I buy MDF form Home Depot. I do not have a place to store full sheets at the moment so I can not order direct which is much cheaper. You can call up local lumber yards and get great pricing but most will have a minimal to buy (around 10 sheet)
what bit did you use to cut out the port for the front piece
I used a 1/2" flush trim bit.
Looks simple and clean. My only suggestion though is when it comes time to notch the edges on the sides for carpet, go 3/4" in on the port side from the front. I noticed you notched the outside edge, must've been a little bit of a whoops.
Mike465
Ami Creations
Mike465
Kennesaw, GA
BeAlLsTaR13
