Bout To Order PG Rsd Sub
jkulysses
Going to order from here unless you guys know of a better deal somewhere?? http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=17536
I found it for a little over $90 on ebay but they are not authorized dealers and onlinecarstereo is so I think the extra $10 or whatever it was would be worth it. I'm just going to use this one sub for now till I can get a bigger amp that is 1 ohm stable then I'll run two of these subs. Going in a sealed box that I'll be making. PG says 1.2cft but did i read on here somewhere that you guys are running them in more like 1.5 or so to hit the lower notes? Pretty sure my mtx 8500 has a burnt coil so i need to figure out why that happened. I think it was a clipped signal so I'm going to try and set the gains with a multimeter this time and am doing the big 3 upgrade at the same time.
wooferetc.com got re SR for $99 shipped
Haven't heard anything about them, any links to reviews? Do they sound good in sealed boxes like the PG subs? Power handling isn't rated very high either.
Nobody else, alright then i'm going to order it from onlinecarstereo tonight. Doin the big 3 on saturday and will probably get started on the box.
"Ideal" flat (Qb = 0.707) is a 5 cu.ft. box. However, the sub can be used in down to a 1.5 cu.ft. box with minimal effect on peakiness(within 1dB of flat) and low frequency extention(loss of about 2Hz).
The RSD is a great low frequency driver. You get a very low F3 (-3dB roll off point) of 30Hz and a sub that's not too picky about box size. The sub does have a couple downsides. First, the sub doesn't really go above 100Hz. Second everything above 60-70Hz is not all that clean sounding(less musically). The sub is geared specifically for low frequency duty. As well, for a sealed, large box driver, it should have a whole lot more excursion. The 13.5mm it's rated for just doesn't go that far. Generally in a large box, sealed configuration, you like to see something more along the lines of 20-30mm xmax. You're pretty much looking at 100dB at 30Hz max of clean output. Then you run outside of xmax into its unclean range. 100dB is enough to match the front speakers and blend musically, but it will be outside of its linear range when you crank it up. I have no clue what Xmech is for the driver, however, PG did put forth an effort to make this woofer durable. They've stress tested the driver off up to 2kW to make sure it wouldn't fail off normal use. The sub can get loud, but it won't necessarily be clean doing so.
I would suggest using the woofer in a largish sized box, a bit more than 1.5 cu.ft., say more on the order of 3 cu.ft. or so. I would also suggest crossing low at 60Hz or 70Hz. However, this forces you to have capable front speakers that can play well down this low, meaning good low frequency sensitivity and high excursion.
jkulysses
jkulysses
Oregon
mvw2
vegang
vegang
