Boomintahoe
[quote name='wew lad']wasnt that difficult for me? or are you talking about the ground strap to the back of the block, because **** that **** its never getting touched unless i drop the motor lol
im talking about the ground on the driver side of the block under the 2nd or 3rd coil pack[/QUOTE]
@wew lad, found where the wire goes to the back of the block. Looks like a few are in the same spot. I need a flashlight to see exactly what I'll be dealing with. Gotta be another ground. Why does this vehicle have so many grounds? 3 to be exact.
[quote name='Boomin_tahoe']@wew lad, found where the wire goes to the back of the block. Looks like a few are in the same spot. I need a flashlight to see exactly what I'll be dealing with. Gotta be another ground. Why does this vehicle have so many grounds? 3 to be exact.[/QUOTE]
you wonder why older vehicles have much better voltage then newer vehicles.
mine has a ground perfectly next to the battery where the intake mounts to and have used it to really get a good voltage.
because GM is smart and knows how important it is to actually ground the block for performance among other things, thank GM - don't curse it. LS engines are the best motors out there (for v8s anyways)
Bro, breaking news today. Did you know that if you take that boat and just change the gear ratios, you'll knock an ENTIRE half second off of your 1/4 mile time?
It came with stock 3.73 gearing.. 2wd..
Its best for quick 1/4 mile drags.
4.10 would be good but i have enough torque
says who? i love the LS but i wouldn't say its the best motor.
they are light cheap and reliable but hell i can name a hand full of V8s that can say the same..
you are hte laughing stock of the forum. you and booming.
Wrong again. Even you know that you're the forum idiot. People have actually gotten so tired of laughing at you that they just simply ignore you now. You are the biggest joke this place has seen in quite a while.
los33
Car Audio G
los33
Houston, TX
wew lad
