Bondo & Matte??
DP&MD11
i am pretty much done with my fiberglassing and i ran outta resin. But i got a alot of bondo and extra matte from my resining process. Is there anyway i can combine the two? Also can i glass down over bondo once i get more resin? Thanx a lot for the help //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
bondo+fiberglass = not good.
the fiberglass needs to soak up the resin (they use epoxy-ish stuff in bondo) - but since the bondo is so thick, the glass wont absorb it, and it wont work well.
but try it if you must.
resin = teh best option period.
its like a bondo, with chopped up mat, mix. you can find it at walmart, HD. etc. good stuff to use.
Is this stuff strong when it dries like resin would? I just need to strengthen my mold and i wondering how should i do that? Or should i just glass more? The curves of the mold are okay i guess but the flat areas have some flex to them.
DP&MD11
DP&MD11
Nipomo, CA
bcarpenterfhl
