bolting to floor
this guy is gonna make a thread later today how to fix a gas tank with a hole in it
Gotta love his enthusiasm, he'll be alright. Wish i was as rearing to go. //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif:laugh:
pics are on the way. I used the carpet as an outline. cut the board down the middle so that when I put it in it would sit nice and snug molded to the trunk.
I did the same as thor. As long as you cut the MDF in the shape of the trunk so it goes in all the side grooves you don't need to secure the MDF down, since it won't be able to move since it has like tabs on the sides. At least in my trunk thats how it worked out. Can't move it at all //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Only thing I put under the floor was a couple 2x4 picese to make the floor level towards the trunk lid. Then put in box tested for best output on the meter and bolted the bixh down.
Can work the same way just measure and cut a piece to fit behind third row seating if you have it. Or if your taking seats out measure and cut you a floor. If your worried about seating you can always bolt bench seats back down through the wood.
Think outside the box. You can do whatever you want. Just make it happen.//content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
I too generally use the factory carpet to make my templates. It's also a good idea to put layer of butyl damping material under the MDF too...
697
No reason you can't get the sound you want with ported or passive radiator but if you have no ability to tune the mass of the passives you will...
taintedplay
taintedplay
dallas
thorshammer1
    May 12, 2024
Brendon Jenness
    May 11, 2024
