Boat stereo question
Hi i just purchased a boat and it currently has a Rampage head unit (35w x 4) and had 4 5.25 speakers. I upgraded the speakers to Rockford Fosgates 2-ways, but it still doesn't sound very clear or loud. I would like it to be loud, so should I change headunits, or would it be better to run a amp to the speakers. Whatever is the cheapest, I just want the speakers to be loud enough to hear over the engine. thanks
i think that will be too much money for a few reasons
1.) New amp will require all new wiring, and strong grounding.
2.) A powerful amp will require Optima batteries, due to the amount of power required
3.) I've already spent enough money on this boat
Any other options?
It's tough to advise anyone to keep a Rampage head unit.
But...if the goal is simply more volume, an amplifier will make a much bigger difference than replacing the head unit. Even a higher power, higher quality head unit won't make much difference in maximum volume.
No need to spring for a 4-channel amp, though. Most 2-channel amps would drive all four speakers just fine, as long as you don't mind both pairs of speakers playing at the same volume.
So how powerful of an amp should I get? The speakers are Rockford Fosgates 5.25 full0range speakers (2-ways). It says peak power is 80 watts. Any recommendations for a cost effective amp?
i think u should get another h/u....the rampage is maybe puttin out 5-10 max rms per channel.(and thats bein nice)....if u got a simple h/u maybe a pioneer or sumtin used that is 50x4..u would be fine..thats prob bout 22 rms per channel....
bigrush
bigrush
Orange County, CA
Sleeklsc
