boat stereo problems
Swisherhauz
Ok I just purchased a 2003 Tige 22I...it has a PRO 485 with a pair of PRO 80's wet sounds on the tower, room for 8 mids along the seats and two 12" subs under the steering wheel.
I have three batteries, and 4 amps. The dealer claimed this was professionally installed or at least the tower speakers were. The installation looks clean.
It is run off a clarion stereo...soon to be an Alpine.
Right now the two speakers in the front work, the tower speakers work and two of the back speakers work and the subs work as well. The system has a fader that you cna turn to either have a mix of all speakers or just tower and rear with subs or just front two with subs. the subs are constantly running.
Putting it on the water this weekend we plugged our iphone in and it would play for a few songs and then clip out and basically shut off. The volt gauge showed no action. But the boat started up fine. it did this time and time again. it would play while running the motor but then it would clip in and out while doing so as well. Now then at a higher rpm, either just trottle (no prop) or while running about it would play fine.
When it clipped out, it would do this at a high volume and at a low volume.
HOWEVER, when I picked the boat up the radio ran fine and then when I was cleaning it it ran fine too! This is OFF the water. All of the above problems were ON the water.
HELP
Swisherhauz
Swisherhauz
Midland, TX
mylows10
