Blueprint Drives..question about an amp...
Schoolbus
7
CA
I have 2 10in 02 series Blueprint subs and have had them for sometime now, still in the box brand new and now i plan to put them in my truck but i have no clue on an amp to power them with, any suggestion would great since i have no idea on what to get for them...
I i can remember correclty they are DVC and can handle something like 600w RMS, but i dont want to put that much power to them maybe 200 or so to each 10....
Also if anyone knows the proper dimentions of a box or airspace need for these subs that would be helpfull as well...
Regards,
School
http://www.diyanything.com/BPD/1002.htm
this is the website of adire Korea's dealer. He's got a stock of BPD drivers.
I suggest you load the parameters into WinISD and figure it out. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Yes, it's 600w, but max, i think. It says pmax. xmax of 32mm, peak to peak.
1.5ohm DVC.
200w sounds alright for the subs, if the sub only handles 300w RMS. If you're gonna port it, then you dont NEED to give all 300w to reach full excursion.
a crossfire 600 sounds perfect for you. you could wire each sub up to 3 ohms then wire the pair down to 1.5(1.5 ohm dvc right) the crossfire 600 is 600 watts at 1 ohm so you put it in at 1.5 you would probably get about a good 450 rms which would put the 200 watts you want to put on each sub. or get a memphis 1000, 1100 @1ohm it is a great amp i loved mine. but if you want 200 per the crossfire sounds great
Schoolbus
Schoolbus
CA
millinivation
