smiley2186
can some1 tell me what the blue part means. do i nead a 2 channel rca or 1 mono channel. when connectin to the slave.
Bridging (strapping)
For bridging into a single speaker load, this amplifier has the ability to be bridged with
another amplifier (must be the same model). To do this you must utilize the MASTER/SLAVE
and PHASE switch settings. On the master amplifier, set the switch setting to MASTER. The
signal is then routed through RCA Line Out to the RCA Line In on the other (slave) amplifier.
The slave amplifier must have the MASTER/SLAVE switch set to the SLAVE position. On
the master amplifier make sure the PHASE swtich is set to the 0 position (factory default).
On the slave amplifier set the PHASE switch to 180, exactly opposite of the master amp.
Refer to the Phase Switches section of this guide.
