blown tweets again
won't matter.
you could use a -3db test tone instead. that'll give you another 3db.
how wouldnt it matter with the car running if u set it for 100 watts its gonna take turning the gain higher since its only at 12 volts then when the car is running around 14volts or so it wont need as much power as u have the gain set to with the car off
thats not how it works.
well i thought it sure was because if an amp is rated to do 100 watts at 14volts and u set it with the car off for 100 watts at 12volts and then when its on its going to be doing more than 100 watts and sending a clipped signal
i have set gains with it off before then cranked it up and checked and the volts were much higher
it shouldn't matter. you're simply comparing input(at the rca's) to output (at the speaker terminals).
and even if there was a difference it wouldn't be big enough to make a difference anyway.
fast85_gt
Banned
fast85_gt
ga
fast85_gt
