blown sub
jakebf2
i just put my subs(2 Dual* 8ohm svc and an infinity 4 ohm dvc) into a new box with a new amp(1200watt kenwood 900watt rms max) and one blew i was thinking maybe it is because it was sealed and would a sealed box effect a speakers ability to be blown if its too small of space? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
well one box all seperate air spaces and it was one of the 8 ohm one's that blew not the 4 ohm wired in series with itself to a 8 ohm load
yeah, not a good idea to run different subs, at all. And no, a sealed box should not blow a sub...i bet you had them wired to the amp all weird and ran at a low load to the amp. therefore producing more power and fried a sub, and i wouldn't be surprised if the amp blew too...stick with one brand and size of subs, and make sure you wire them right...
no its all wired good. the 2 8ohms were in parallel with each other and the single 4 ohm in series. so i took the broken speaker out and now i just have a single 8 ohm and that 4 ohm wired the same and sound great still just minus one speaker.
dont do that. do you not listen. running 2 different voice coil configurations is bad for the subs and amp.
So you think an amp will see a difference between a svc 4ohm sub, and two 8ohm subs wired in series?
Running different subs is (almost) always a bad idea... but lets at least give some plausible reasons why. Especially if you are gonna call people morons.
yeah 2 8ohm will wire down to 4ohms then you can wire in the 4ohm but its probably not going to work. the different coils will get different amounts of power and more then likely will result in a failure.
lets say his amp will do 1000watts at 2ohms. each speaker isnt going to get a third of that. most likely the 4ohm will more and the other 2 will get whats left. electricity flows through the path of least resistance and 4ohms is less then 8ohms, so more power will flow towards the 4ohm coil
dont know if that helps any
You are confused. My point was you keep saying its bad for the amplifier, its not. Its bad acoustically, but to an amplifier its 4ohms, no matter if its a single 4ohm SVC or 100 speakers wired up together to a final load of 4 ohms. You can have an SVC 4ohm speaker wired to one channel of your amp, while having two 8ohm speakers wired in parallel to the other channel. You are correct in that the SVC 4ohm will receive half the power, while the other two 8ohm units receive 1/4 of the power each. But you are incorrect that this is bad for the equipment.
jakebf2
jakebf2
someware
audioholic
michigan born
    May 14, 2026
michigan born
    May 14, 2026
