Blown Amp
SageFrancis88
I recent bought an amp from devastating devastating_mat. It is a concept 2400. It worked perfect for the first 3 days then at low volume it made a click noise and started smoking a little and turned off. I turned everything off. I opened the amp up its burned on the circuit board. I was wondering why this happened? Its wired up to one DC Sound Lab Level 3 15" tuned to 28hz. Wired at 2 Ohms. Gain was 3/4 up. 1/0 Gauge wire.
That is quite a bit, but that alone couldn't burn it up.
The only reason the voltage would have dropped is from the bass hitting but like i said it was on low volume, not hitting hard at all. I dont understand why it fried.
The damage can be done and it will simply fail later on when you don't expect it.
The failed parts are power supply FETs, which generally are killed by people with voltage drop due to either a gain setting too high and/or bass boost too high combined with inadequate electrical system support.
SageFrancis88
SageFrancis88
Chicagoland
SageFrancis88
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
