Blowing Tweeters!!!
Well, then it might be the xovers.
I'd put your tweeters at -1.5 then... to protect them a little...
nG
there is no audible distortion.. the crossover's light up if you are sending them a unclean signal... have yet to see them light up...
allso like i said im swaping out the old with a BN set. any seggestions other then the -1.5db setting on the tweet?
Well, if the bulbs aren't even lighting up... it might just be the xovers and the music being listened to.
I know the only time my tweeter blew was when I was listening to some LOUD rock a little louder than I should have been... but it was still only the one side.
nG
nG
see that's the whole thing... im not even getting close to being LOUD... im listening to it at the level where i can still talk to the person in my pass seat.. once i go above that level that's when i notice it gose out...
allright well im going to go get my new set of x types.. i'll be back to let ya know how it gose...
Werd. That's weird if you aren't really cranking on them...
nG
yea i can see if i was doing that... but i rarely do... my roomate ( allso a installer ) was like man you need to stop wangin on em.... well he was with me last night when it went out... now he has too witnessed at what level they went out and allso found it wierd...
One channel of your amplifier is putting out more power than the other channel.
I had this exact same thing happen to me, except with my active setup. Same tweeter blew 3 times...
All 2channels don't put out the EXACT same amount of power... put on a sine wave... and use ACv on your multimeter and I'd bet willing to be one channel is slightly higher than the other. Like my kickers.
Also, you're a fucking installer... do you know SHIT about car audio?
nG
not trying to diss your professionalism (lol) but I did a sine sweep and it blew my tweeters SOMEHOW and I had the type R comps bridged on an Alpine MRP-F250. and I had the gains between 1/4 and 1/2. but if your having one side blow... do what they said and also try switch the comps' crossover from one side to the other to see if that would be the problem. and if it is then obviously the one that is causing the tweeter to blow is bad...
thank you sir... do you manuly put in nG everytime you make a post... just wondering..
i just got a brand new set and re installing them now..
You talking to me? Whenever you test voltage on an amplifier, you should do it WITHOUT a load on the output. So, disconnect your speakers when running a sine wave and testing the VAC...
Yes I do. It's habit. //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
nG
Also check the speaker wire from the tweeter to the crossover. If it is grounding out or getting pinched you will keep blowing tweeters.
Could also be the x-over, but check the wiring carefully all the way through the install.
nG
see i knew about that....
i like the little personal touch...//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Indeed. Easiest way would be to check both the positive and negative wires with continuity with ground...
nG
SethPhillips
I'sa Playa
SethPhillips
Northern Utah
bluelceii
