Ground Loop?
IDSkoT
Resonating Reticular
It seems a few people are having this same problem as me now.
I went to set the gains on my amp with a newly acquired Radioshack DMM, and my Moms asked me to move my car so she could get out. Prior to this, I had turned my car on and off maybe 3 times in the course of an hour. Trying to set my gains and I didn't want the battery to die, but I couldn't figure it out (and stil lcan't).
So, the last time I turned it off I heard a pop but didn't think much of it. When my mom asked me to move, the pop happened when the car turned on, and I heard alt noise (whirring sound that increases in pitch / volume when the engine's reved).
I'm guess it's a bad ground... maybe off the speaker amp? [i have a JBL 750.II or something like that... it's a 104x4 @ 4-ohm amp and a Boss 1200M which is 600x1 @ 2-ohm]
I also have a Pioneer DEH-P6900UB for my HU. Should I ground that and see if it helps? I kind of want to avoid pulling the HU out since I lost the clips for them and I don't want to scratch or break anything with clothes hangers if I don't have to.
Help?
EDIT:: and if it is a messed up ground-- why'd it just now start messing up? I've had that set-up like that for a couple of months now with the gains set at an audible level, rather than with a machine (DMM or oscilliscope).
I can't find the pic I was looking for, but there are two ways you can do this:
1. ground loop isolator from radioshack, or audio store(goes inline with the rca's and has 2 brown wires to run to ground
2. simply strip the end of a pair of wires and insert them in between the rca cable and the hu's plugs(contacting only the outer rind on the rca plug and not the center pin.....then run those 2 wires to ground
I can't find the pic I was looking for, but there are two ways you can do this:1. ground loop isolator from radioshack, or audio store(goes inline with the rca's and has 2 brown wires to run to ground
So, if I get the ground loop isolator it's pretty much certain it'll fix the ground problem?
Here's what I did to fix my pioneer alternator whine
Sure did. Common practice around here to do so... Easy quick fix.
Nice. I did it (for not 'till I get some bread to buy some actual ground loop protectors, and worked pretty well considering on what I used and how ghetto rigged it is. BUt, as I said, it's only temporary.
I was also wondering if anyone could tell me how the f*ck I get the volts to set my amps? I know what the voltage is supposed to be, but for some reason I get my DMM to work for sh*t.
Radioshack, eh?
It looks like a regular DMM
http://www.radioshack.com/product/index.jsp?productId=2103176&cp=&sr=1&origkw=digital+multimeter&kw=digital+multimeter&parentPage=search
For some reason, no matter what I put it against, and what settings I use, it gets some ridiculously low number. Can anyone please spell it out for me? I read the manual, and did what it said... and I guess I'm just retarded.
I turn it to the volt setting, I choose DC, and I prod the screws for the output with out the speaker cables in... and I don't get squat, man. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif HALP!
(And yes, tone CD on with no eq and bass boost down on 75% volume)
EDIT:: I did have a hard time getting those wires to loop around.. what I ended up doing was making a loop with my pinky, putting it around the jack and putting the RCA in, pinning it in, then used it to tension it and kinda wrapped it around the other... and repeated for my subs.
The wire around the RCA terminals is better than any ground loop isolator or protector.
The isolator/protectors will only cover up the problem ... the wire is re-grounding the RCA's; This is the source of the issue.
IDSkoT
IDSkoT
Miami, Florida
rumple4skin
