blowing fuses
colgatekillaa
ok so im running 2 10 w6's and they're wired to 2 ohms, so each are probably seeing around 500 watts, probably less then that because i haven't upgraded my electrical at all. recently i have been cranking up my music and amp shut off. i check the in-line fuse and sure enough its blown. i didn't think anything of it, i just replaced it to see if it was a fluke, lol to that last part, and of course the second one blew. Im running 4 gauge wire into a 60 amp fuse. i was considering just getting a bigger fuse, but im not sure about that. i will be doing the big 3 soon and i was going to run 1/0 to the amp but im not sure if thats necessary or not. the amp is the rf T8002. i was just wondering if upgrading the wiring would fix this problem or what you guys think i should do.
thanks.
exact same situation i was in earlier today........my amp shuts off, no power, i was like ****.........checked amp fuses, they were fine. checked inline fuse and it was toast. I had only a 60a fuse and 4 gauge, and it wasn't enough.
When i got the fused replaced I upgraded the power wire to 1/0 and did the big three in 1/0. I have a 150a fuse now. Only difference is I have 1800w
Be careful just replacing fuses. The amp may be over drawing the fuse and blowing it, or there could be a short.
Before you even consider putting in a bigger fuse, you should check that wire for problems.
colgatekillaa
colgatekillaa
San Francisco, CA
johnecon2001
