Blow through design for two 10s. 4th order
So I currently have two re audio se pro 10s. About 800 watts a piece. I have them in a 2.9 cft box under the seat of my 01 silverado tuned at 34hz. I want to do a blowthrough to get a little louder but better sound. So 4th order it is. I have 6cft to work with. 48" across. 18" high and no more than 16" deep. I plan on using 4" aero ports but need help on everything. I've never built a 4th order but love there sound. I want it tuned low to dig on the deep bass. Here's the t/s on the subs
10"
Electrical Q Value -Qes: 0.46
Mechanical Q Value -Qms: 4.4
Total Speaker Q Value -Qts: 0.42
Free Air Resonance -Fs: 26.6 Hz
Equivalent Compliance -Vas: 31 liters
One-Way, Linear Excursion -Xmax: 18 mm
Efficiency -SPL 1W/1m: 83.2 dB SPL
Effective Piston Area -Sd: 310 cm^2
DC Resistance -Re: 2.8 ohm
Nominal Impedance -Znom: Dual 2 or 4 ohm
Thermal Power Handling -Pe: 600 W
Force Factor -Bl: 17.7
I'd prefer to build the box as little as possible. Since it is going in the bed. I can cut the lengths in any direction. But I'd prefer to do shorter depth.
Synastr
Synastr
Crossville,TN
CSCStang
