do as suggested about the bolt at the rear door. but running a wire to the battery leaves room for easy upgrades if you ever need more grounds. that one wire from the battery can go to a single amp, or to a buss bar, which can then split and go to 3-5 more ampsi grounded to the seat where it bolts down and im gitting a 4 volt drop and i really dont want to run a wire to the bat
