Biggest amp I can go with on a stock alternator?
I got me a 07 Chevy trailblazer and I need to know about the most rms I can use with just the BIG 3 done, really good aftermarket battery under the hood and stock alt. I'm hoping I can get away with about 1500 rms to subs and 300 rms to mids/highs. I can find out how many amps my alt is if that will help.
I have a 145 amp alt on my 2011 chevy truck with a hifonics 1600.1 and 640.4 with two sundown sd 12s. No big three has been done. All I did was go to batteries plus and buy one of those X2 power agm batts. I get 0 dimming and 13.9 volts with not drop at all.
Should be ok. I used to be running 2 pioneer subwoofers with 2400 watts rms to the subs and 400 watts rms to the speakers off of a stock battery and a 30 farad capacitor and it ran just fine when I had it. I now have the same setup only difference is I put an optima yellowtop battery in the front with a kinetik hc600 in the back and the big 3 no dimming and only a slight voltage drop with impedance rise under load.
I think you'd be okay with 1500w monoamp and a 4 channel. You might get away with more, you might not. You could always get a 2000-2500w amp, set the gain with a multimeter and see how your voltage is, if it is dropping too low back off the gain until you are happy with your voltage drops. I had a truck with a 130a alt and would drop into the low 11's with a zx1500.1, my last car had a 85a alt and I was in the low 12's if I remember right with a saz-1500d@1 so it really depends.
I think my voltage issues on the truck may have been an issue with the computer controlling the alternator.
I recommend OFC all day long. You can even pull it later on and use it again if need be with little to No Corrosion. Run Power wire from battery...
32
Personally I recommend stereo integrity speakers. M25, M3Carbon, TM65MKIV They also make fantastic Amps and subs Amps In the configuration you...
72
112
110
Thanks for all the advice. Ultimately, I was able to get them to honor the warranty contract. It took a lot of back and forth and I received...
242
HoovaDeuce 82
Ft.Worth, TX
jdawg90
