Biggest amp I can go with on a stock alternator?
I got me a 07 Chevy trailblazer and I need to know about the most rms I can use with just the BIG 3 done, really good aftermarket battery under the hood and stock alt. I'm hoping I can get away with about 1500 rms to subs and 300 rms to mids/highs. I can find out how many amps my alt is if that will help.
I have a 145 amp alt on my 2011 chevy truck with a hifonics 1600.1 and 640.4 with two sundown sd 12s. No big three has been done. All I did was go to batteries plus and buy one of those X2 power agm batts. I get 0 dimming and 13.9 volts with not drop at all.
Should be ok. I used to be running 2 pioneer subwoofers with 2400 watts rms to the subs and 400 watts rms to the speakers off of a stock battery and a 30 farad capacitor and it ran just fine when I had it. I now have the same setup only difference is I put an optima yellowtop battery in the front with a kinetik hc600 in the back and the big 3 no dimming and only a slight voltage drop with impedance rise under load.
I think you'd be okay with 1500w monoamp and a 4 channel. You might get away with more, you might not. You could always get a 2000-2500w amp, set the gain with a multimeter and see how your voltage is, if it is dropping too low back off the gain until you are happy with your voltage drops. I had a truck with a 130a alt and would drop into the low 11's with a zx1500.1, my last car had a 85a alt and I was in the low 12's if I remember right with a saz-1500d@1 so it really depends.
I think my voltage issues on the truck may have been an issue with the computer controlling the alternator.
I agree with others, just buy the OFC. My last wiring was oversized CCA, and while it still works, and looked okay when I peeled the heat shrink...
82
The audio frog gb subs do have good output but aren't spl monsters I'd compare them to the w6 output wise while I believe they sound slightly...
96
126
114
Thanks for all the advice. Ultimately, I was able to get them to honor the warranty contract. It took a lot of back and forth and I received...
248
HoovaDeuce 82
Ft.Worth, TX
jdawg90
