big three question?
Micah7x7x7x
Bass head
ok so i have a question about my eletrical system i have a high output alty put away that im saving for but it will be a while till i get it so i was wondering if i could go ahead and do my big three upgrade with with a stock alternator so i want have as bad of voltage drop and my car will actually start without me having to jumpstart it?? i have a 1993 plymouth acclaim if that helps and a everstart maxx battery
Big 3 can be done at pretty much anytime, will help with voltage drops. Make sure you have solid connections, sand paint off any grounding points, make sure the ground goes to the frame etc.
You can use 4 gauge, I would use 1/0 it can be bought for pretty cheap on knukonceptz.com and you will see the best results. No use in doing it twice if you ever wanna go bigger.
Micah7x7x7x
Bass head
Micah7x7x7x
Tennessee
Micah7x7x7x
