big *** problemm...
blackxj
All Things That Are Good
well my subs just stoped workin so i kinda need help
the coils in the subs are fine...
the amp is not in protect..
i used my highs rcas to test my deck(see if my sub rcas where bad)but its fine
i ree wired my whole truck and that still did not work
it started this morning the subs would be playing than cut off than play again than they finaly just turned off
im thinking i blew my amp.....
help me out ca..
Turn your system back on. Take a DMM and test the outputs on your amp. The speaker terminals. Set it on AC and see If there is any voltage. Turn the volume up and down and see what it does. If no voltage is present on the amp. Then your amp is fried in some way.
Did you rewire the box and amp speaker wires. And How do you know the coils are fine???
amp for sure..but you can try your subs on a different amp to see if that rules out it being your subs. Same happened to me...rewired and rewierd again and it was just the amp
fmlll.....treo=fail fail fail
blackxj
blackxj
eastern li
smgreen20
michigan born
    May 14, 2026
michigan born
    May 14, 2026
