big problem
is my amp blown off
  • is there bad wiring
    Votes: 1 100.0%
  • or is my amp blown
    Votes: 0 0.0%
  • Total voters
HELLHAMMER
i i just got my new amp and sub yesterday i insatlled it properly , the power led is ON on the amp, and the wirin seems fine , i jacked the + with the + and - with - on my 10 inch sub , but nothing is happening!! can someone help me with that , the battery is correctly connected , the remote too and the rca cable behind the radio are on the sub plugs! , if my amkp would have been blown the power wouldnt get in?? , can csomeone help me thanks!
exaclty im using a dual amp 450 watts , and one lighting audio 10 inch sub in a q logic case with stinger cables
I'm going to resist commenting on that and just say exchange the amp for a new one cause it was DOA and if the new one doesn't work check all wiring, if it still doesn't work get a different brand
if is DOA it wont turn on, so its noy DOA. Triple check all the connections. It might be a bad RCA connection. Pull it out and put it back in, does it make a pop noise in the subs?
i checked the rca 4 time fromthe amp , to the radio , rechcked the remote , and the power is on so the 12v is well connected on the battery , i have 2 left +and- connection and 2 right +and- connection on the amp , i tried left posite and negative , i tried the same thing for right , and i also tried , left+ bridged with the right - so do you have another option??
do the rca thing.
if you have a spare rca liyin around plug one end in, then tap on the other end, you should hear a tone from your sub. See if that works, if it dosent your amp is busted
HELLHAMMER
HELLHAMMER
quebec canada
HELLHAMMER
