Big Amplifier(s)
  • 5
Im running a 12v system, and doesnt the HV signify high voltage, which means that it is designed to run on 16/18v setups? Ive done the 16v daily driver before... Not happening again. Sticking with 12v.
yes, the HV stands for high voltage. But can be ran on a 12v system just fine. The DD Z2LV which is designed to run on a 12 volt setup produces more power at 12 volts compared to the HV.
2012 Civic Si, and yes 4awg, didn’t see a need to go 0/1 since I’m only installing the mono D amp the subs, anything further would require...
970
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
I will still find the blame..Bad tool, cheap connectors, junk wire..LOL 🤣 🤣 I didnt have enough B12 this morning is my favorite
23
galacticmonkey
Wants a button like that.
galacticmonkey
Tampa, FL
ty_houston
