Big 3 ???
if it's running close to the engine block what is that suppose to do to the wire? I thought it was acting as a fail switch in case the alt pushes too much current to the battery so it won't overcharge/explode.
you get an inline anl fuse holder. you fuse it according to the thickness of wire. with 1/0 guage i would say 250-300 amp fuse
I know about the fuse holder...How do you connect wire to fuse? do you have to cut it or does it plug right into each end of the fuse holder? I imagine it will look similar to the 4 guage wire I have running from my positive terminal back to the amp. I don't know how they fused the wire. I never did an install but think I can tackle the Big 3.
jlpimpin
jlpimpin
marietta, ga
jlpimpin
