jlpimpin 10+ year member
Can I use 1 or 4 guage replacement battery cables-From Aadvance Auto-- in the Big 3???? If not where could I purchase all the equipment for this project????
If all I need is power wires would walmart be fine if I can find some?
how do you fuse the battery wire?
I doubt there is a sensor connected to that thats going to mess with youIf you run an external fuse, wont your car see its not getting current through the stock fuse and put up an annyoing warning light???
I know about the fuse holder...How do you connect wire to fuse? do you have to cut it or does it plug right into each end of the fuse holder? I imagine it will look similar to the 4 guage wire I have running from my positive terminal back to the amp. I don't know how they fused the wire. I never did an install but think I can tackle the Big 3.you get an inline anl fuse holder. you fuse it according to the thickness of wire. with 1/0 guage i would say 250-300 amp fuse
