Big 3
good afternoon People,
ok here it is .....Starting a build on my Cadillac DTS....1st up...Rockford T1000BDCP....next big 3 upgrade...my Challenge is that my battery is under the back seat...Suggestions?....obviously upgrading alt wires and battery wires...the wire from the battery to the Fuse panel?
any help is appreciated....oh by the way alt will be either upgraded or respun and the batery will be upgraded....total system will be in the 2000watt area....Would rather have to much electrical than not enough..
Fuse panel? Not sure why there would be a wire ran to it from the battery. Also....is that normal for that car to have a battery under the rear seat?
I have a charger and the battery is in the trunk I had 2runs of wire from the alt to the trunk with fuses in between the batteries. I did 2runs of grounds off the alt bolt with a wire from the alt bolt to the engine block, and one to the factory ground under the hood.
Thank you, My question is should i run a new wire from Battery to Fuse panel, Battery is Under the Back Seat.....Thank you again Guys
idk about fuse panel but guy here has caddy with battery under seat no big 3 but oga ran back there to 2nd batt as well and with battery close by looks like it works well..
Deadlift7212
Deadlift7212
New Britain, CT
BOOMINGRANDPA
vegang
vegang
