big 3 ?
What are the cables your referring to? When your doing the big 3, you leave the stock wiring alone, there's no reason to remove it. Just add the 3 wires...
so im not replacing any wires:confused: i just put new gounds along with the old grounds and the stock alt to batt with the new alt to batt
yes! Your making this too complicated...your not replacing anything, your not removing anything, your simply adding...
wait i just called my dad and he said that running alt to batt will leave the alt on and it will drain my batt so he said that it wont work
Yeah your dad is an idiot. I as well as every other person on this forum basically have a wire straight from my alt + to my batt +. You're not the first one to ever do this.
Ask your dad how current can flow from the alt when it is not turning. If it can, then you have a magical power source and you have solved the earth's energy problems.
Then this forum would be full of dead battery mofos. Im a dad and I say your dad is stoopid as fauk.
I did the Big 3 on my sons car and what do you know, 8 months later, No Dead Battery.
except that my dad has been in atomotive for over 15 years so i think he knows what he is talking about.
Yeah he may know how to fix the mechanical problems on a car but it sounds like he doesn't know shit about electrical. How can an alternator drain a battery? Ask him to provide a detailed explanation...
the Answer
DC audio FTMFW
the Answer
sumter county, Fl
Villeza1
