big 3 on a trailblazer
I did my 02 tahoe which run are u having trouble with... grounding the battery is easy the hardest is ground to engine block but on my alt there was a nut that said GND on the alternator bracket the power to batt is easy find the red nut remove it bolt on ur wire and bolt it to ur positive terminal PM with questions... probably wont check thread.
hope that helps
Joe
trey u've been giving all this useless info and u drive an envoy? give me a break thats the same **** thing as a trailblazer... u mind enlightening as to if there is anything i should know before i go and do all this?
andrewmoore13
andrewmoore13
Gloucester, MA
andrewmoore13
michigan born
    May 14, 2026
michigan born
    May 14, 2026
