eggyhustles
i'm lookin' @ a tut for the big 3 in a civic coupe and see this.
under the hood, instead of the pos batt goin' to the alt it goes to a fuse box.
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
thoughts?
is this part of the big 3?Once you remove the main positive harness of the battery, fuse box, abs and starter wire. It will come off as one hunk. I'll put pitures of that up later since the camera died. Take your new wire and measure it all to the length of the harness removed. Then all you have to do is cut, crimp the new terminals onto the 4 gauge wire. Next insert the measured wire with the new crimps onto the new battery terminals. Follow the directions off the new terminals. Most use allen wrenches to tighten. Simple r&r. Repeat for the gorund wire and your done.
Here are pics of the starter wire and ****** ground.
thoughts?
