Hey guys.
Made a post earlier in the week asking a couple questions regarding Big 3 upgrade. Well, I completed it today. To say im disappointed would be an understatement. Ill take you through my setup, how I did it and ask for advice.
I ran 0 gauge from alternator positive to battery positive, battery negative to ground (frame rail that I used an electric grinder/sander on) and engine (i chose a bolt of alternator), to the same ground area on the frame rail. Not on top of one another, but about an inch or two apart.
After completing my install, I have ZERO improvement. Normally, first thing in the morning (prior to big 3), my voltage at my amps would be 14.6. Same now. But, I get massive voltage drops into the upper 10s to 11s, and my lights still go bonkers in and outside of the truck.
I realize im running not only 1, but 2 pretty power hungry amplifiers(RF T10001BD bass amp AND a JL 450/4 for components) but still. Im also still keeping my capacitor in line for the bass amp.
So, im stumped. Did I miss something here? I see most people run engine ground right to battery negative. But it's all the same, as long as its grounded, no? Is my alternator toast? Can I do anything about it? New HO alternator isn't in the budget currently. Runs around $600 for my truck.
Im just at a loss. Any help, tips, would be appreciated. Thanks!
EDIT. ALSO, I BELIEVE STOCK ALTERNATOR IS 110 AMPS. BATTERY IS FAIRLY NEW, 810 CCA
