Big 3 Dissapointment
Here's the reality:
For constant, reliable voltage with a decent sized sub amp, you are going to need a good quality battery(s), a alternator up to the task, AND the big 3. You pretty much need all three working together to prevent voltage drop.
The Big # upgrade makes a more noticable difference with the larger alternators, your little alt isn't big enough to need larger wire, which is why you didn't see a big difference.
The best bang for the buck fix would be to add a second AGM battery in the back next to the amp, but the ultimate solution will be alternator + battery. You have to pay to play, unfortunately.
Here's the reality:
ok so what if my main battery is right next to the Amp, my main batt in the HHR is int eh back, amp is in the back also. I was thinkin about just doing a kinetik 1400HC.
I have 90 amp alternator and i was thinkin upgrading to 0 gauge through out the car.
Amp - PA 5500d gothic series amp. 150 amp fuse
plus 4 channel amp ect.
Should i not bother with 0 gauge? or should i still get 2 batts, right now from what i know there isnt an ho alty for the HHR yet
budahbuddy803
budahbuddy803
Aiken, SC
chunky cumz
