What do you mean by the Top of the Line Clarion 2005...I thought that the DRZ has been the flagship top of the line model through 2004 and into 2005 and perhaps into 2006??
So....once again... having a 5 Band EQ and no 24 DB slope will affect me how bad? Its just hard to swollow given that it lacks only those 2 things and that it has everything else I could want. I just personally hate bottlenecks in systems.
Just to clarify...when talking about a 24 DB we are speaking of a volume boost right? 24 decibles? and the 5 band eq is good for both the mid and the hi? of course a 10 EQ band would give me better control and tunning and all...but by much more?? The good news i'm hearing about the DRZ is that is has good Xover capability right? and that if I were to get an external EQ I would have to get one for each channel?? 8...?? 1 EQ for my highs...1 EQ for my mids...I don't see why I need one for my sub....the sub should be a bit easy to setup... I always cross it around 80hz.
Orangeblast....The DRZ is a great deck, dont get me wrong. It could be the deck for you if you are a novice , just not enough for most with active needs. Dont get sold too much on the DAC's, plenty of people are running lower grade dac Alpine combos just for the flexibility. I have a buddy that just sold hids DRZ for an Alpine combo.
In the active world tuning> all
Its just very disappointing that the only deck in the market with 4way xovers, an active dream....in on the same token an active disapointment as far as EQ.
Isn't the reason to get a DRZ is to go active?
Simply put the eclipse has greater flexibility in 3way active, but obviously does not support 4way. Just letting you know the facts.
The beauty of going active, is that once you have a system to support it (amps), one tries all kinds of different speakers from time to time. Not all speakers perform the same, specially in a car...in your desired locations. EQ is your only friend at that point.
Also steeper slopes help integrate speakers better. For example I have dome midranges with a resonating frequency of 380hz. Rule of thumb is that normally close to double that frequency is to be used as a xover point to avoid bottoming out, resonances out of the driver while used IB. But because I have up to 24 db slopes I'm able to play them down to 500hz with
24db slopes and be able to pile on the volume better. Change the slope to 18db, or 12db...and I cant get the same volume out of them without distortion. Steeper slopes allow for smoother rolloff onto the other speakers. Dont let your HU, decide what speakers you can or cant use because it limits your ability to use them to their fullest in your car.
