better mid - bass or whatever
dru
Anyways my current set up involves:
clarion dxz745mp
crystal csc60s powered by planet audio amp
adire shiva 1.0 cuft sealed box powered by jbl amp
knukonceptz wiring all around
I feel as if there is not enough mid bass.. I want to add possibly 8 inch woofers for more of a kick i guess. How do i go about doing this.. building two enclosures? running free air? wiring it to my rear output or suboutput? just wnat to kno what other guys ahve done.
plus i have really done research on 8 inch woofers... ive been readin on peerless alot.
any kind of help works.
thx guys
You will need a seperate amp. You also need to bandpass the midbass between where the sub leaves off and the mids pick up. If your comp amp can low or high pass it's RCA preouts *Assuming it has them* then you can get away without an external crossover.
BTW nice setup, Shivas are awesome.
thx man
You also need to bandpass the midbass between where the sub leaves off and the mids pick up. .
and... By this you mean what? If you can explain this a bit more in detail I'd appreciate it.
Sorry about my last post's 'typing ignorance' I just got done hitting a J earlier. heh
bandpass= lowpass and high pass at the same time.
ex: 75-250 Hz.
Low pass =250Hz
Highpass=75Hz
The driver will only play a frequency within that range. Note: I just randomly picked those frequencies.
clarion dxz745mp
thx guys
Get the peerless cheap through me I'm tryn to get the price down to about $50/ea //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
dru
dru
Blacksburg, VA / Chesapeake, VA
dru
