Best wiring option for 2 sundown audio x12s with creciendo BC3500D
Okay. Now may ask why you choose .5 ohm over 1ohm? I just wanna know how much of a difference it would be. Why do some people recommend .5ohm and some 1ohm Sorry. I know how frustrating it can be to deal with noobies but I just wanna make sure I'm buying everything right.
Most do it to defeat box rise. You are asking the right questions dude, we all have had these questions in the beginning.
Wiring to .5ohm reduces the margin of error. Your amp is going to to be working harder and in this case the subs will be pushed even further past their rated spec.
I'm not saying it can't be done. You can still fry the subs at 1 ohm depending on the setup, but here 1ohm is more forgiving than .5.
Yeah I wish I knew more about electrical and stuff. It's just that I'm putting obviously alot of money into this. I wanna learn and do it right you know? I have a friend who's really smart and actually builds his own woofers but he's busy and can't teach me everything. Lol
Okay. What size battery should I buy for the 2nd battery. I got xsd3400 under the hood 240amp mechman alt big 3. Gonna be running the 2 x12 with crescendo 4500 and 500 watt 4 channel amp
The TS uses a 4.5k specd zenon board. They dyno 47-4900w...lots of dyno vids on it
The encore is same board as Audio Legion 5k, which is actually stronger because AL uses better components. It dynos more than the encore
zenon has the NC, RSVC, ZDBUL. the RSVC are the compact designs and the NC are the higher power designs. the ZDBUL4500.1 looks similar to the TS3500.1. id say they are probably similar in output to the cresendo..the encore to use the 5kw NC5000.1 board and honestly it looks a tad better. i cant speak for the internals ill assume your tested them and have more information. I'm contemplating on using zenon but i want something different.. i know for sure the Tw is very strong. it made my prototype **** lol.
does the sendo 3800 looks similar to the zdbul 2500.1 modded. regardless the are all great amps. BTW just upgradeing to higher powered transistors can have some side afects. you often sacrfice slew rate and output inpedance with going with higher powered transistors vs adding more smaller ones.. not going to start a war. my point was ID rather recommend he run more power at 1 ohm than get a 3500 @ .5 the encore was in his price range.
glad you did bring that up though..
bgaff45
bgaff45
Wallingford, CT
kr15
