Best way to wire these subs
Cgballin2002
I have two pioneer premier subs. They are dual 4 ohm.
My hifonics amp is one ohm stable. It is a mono channel amp but has two positives and two negative connectors. I want to get a 1 ohm load from my amp.
The box I built has a divider for the speakers (so each sub is in a 1.0 cubic ft. box.
I might look like a dummy posting this but I am new to wiring dual voice coil speakers. So could someone tell me which way is best to wire my amp.
I am really sorry for the goofy pictures but I want to get this right.
Would the second pic still give me a one ohm load.
Hold on one second. Is the Hifonics a single channel amp. What is the model number, I think the second pic you have up is correct.
This is correct.
Some amps like yours have two positives and two negatives that are internally connected together. They are the same. The second pic will also give you a one ohm load. So you are good.
AUDIOBAHN A8000T MONO BLOCK 1600 WATT AMP, thats the kind of amp i have and these are the kind of subs i have 2 AUDIOBAHN AW102N 10" SUBWOOFERS 1100 WATTS Single 4 Ohm Voice Coil
I know its not that best system but oh well, im just not to sure on how to wire them up.
Cgballin2002
Cgballin2002
Gator Nation
phillyphill39
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
