Best Way To Wire My Subs
ianlaliberte
Hi any help appreciated.
This is what I got. Found some old equipment that is brand new just need help with the best way to wire the subs.
2 12" Kicker Comp C12
going to
1200 watt Sony Xplod 2/1 channel amp
Comps are 4ohm
What is the best wiring. Diagram would help. I obviously want the most boom for my buck
Thanks
going to
Comps are 4ohm
Thanks
those are svc 4 ohm subs.. ive ran a pair of c10s in the past..2 ohms for a pair
If its a 2ch amp that's bridgeable to 1 channel than you will need to hook each sub to a separate channel. Each channel can handle down to a 2ohm load, but bridged it can only handle a 4ohm load, so if you wire them together and bridge the amp you will fry the amp.
those subs actually get pretty decently loud and do great in sealed enclosures..like 1.8 sealed each
I have a 2015 Dodge Ram 1500. I bought a Qbox enclosure for under the back seat. This is what it says about the box.
Q Bomb Dodge 12 4 Door .65cu 6" Depth
---------- Post added at 08:11 AM ---------- Previous post was at 08:10 AM ----------
So the 2ohm will be safe? And will the low end be good?
Others are saying 2ohm what the difference e going to 1ohm? Do I get better bass? Will it be safe?
---------- Post added at 08:14 AM ---------- Previous post was at 08:13 AM ----------
Someone else mentioned 1 ohm. What's the difference?
You have to wire each channel to a sub. Your only option is going to be to run at 4 ohms. The upper bass will be ok. But you won't have a deep low end.
^^^right. your amp is not 2ohm (bridged) or even 1ohm stable, you will ruin the amp. one sub per channel.
Not friends at all. I see are you are another JP hater with zero proof of anything. He wasn't even driving that truck. Haters will always hate. He...
16
Kodas like big sealed boxes and can't handle power. I shredded the surround on my 8 in .4ft³ and 350w My 10s on 1000w for the pair one coil...
292
463
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
463
ianlaliberte
ianlaliberte
boston, MA
JarodM
    May 31, 2024
    May 24, 2024
