Best way to wire 2 Rockford T1D412's
You can run a single positive wire to each positive terminal and run a single negative wire to each negative terminal (both on both subs) to make 1 ohm the easiest way.
Amp + to sub one coil 1 + to coil 2 + to sub two coil 1 + to coil 2 +
Same as above for negative just go negative, not +
How many amps is the alt in your car? Unless it's a Yugo or something you should be fine wiring to 1 ohm with good 4 gauge wire. You're not going to see 900 @ 1 out of that amp anyway.... If you do wire to 4 you'll hardly move the T1's.
I would just wire to one ohm and make sure you set your gain the correct way and there shouldn't be a problem. Or Try it both ways and if there is not a big audible difference just keep it to 4 to make it easyer on the amp
It is STABLE at 1ohm, so it should be just fine, as long as you dont set the gains Maxed out/be conservative while setting the gains,and you should be just fine
i would not wire that amp to one ohm, the fact kenwood rates it 900 at 2 ohms and 900 at one? id stick with 2 ohm or less and my friend learned the hard way wireing it to one ohm on two cvrs and the amp fried in 4 weeks
Question, if i have both of the subs wired to 1ohm at the amp, will the amp see 2 ohms because there is 2 subs at 1ohm? Thanks for all the great answers!
USAFradartech
USAFradartech
Goldsboro, NC
audiobaun
