I am buying 2 sets of Alpine Type R Comps. Do I need a 4 channel amp to run F & R or a 2 channel amp for the fronts and run the rears off the head unit (kenwood x889)? And will it be ok to mount the amp in the trunk since I doubt I can fit it under either front seat?
Here are the speaker specs:
350W Peak Power
70W RMS
Frequency Response: 35Hz - 30kHz
Wave Guide
This is the 4 channel amp I was considering if I need that much.
Kicker KX650.4:
~ 2, 3, or 4-channel output
~ 81.25 watts RMS x 4 at 4 ohms
~ 163 watts x 4 at 2 ohms
~ 325 watts x 2 in bridged mode
~ Front and rear high-pass/low-pass crossovers (variable 50-200 Hz, 12 dB per octave)
~ Front & rear Bass boost (0-18 dB at 40 Hz)
~ Remote gain control with 25-foot cable
~ Frequency response 20-20,000 Hz
~ Requires 4-gauge power and ground leads
~ Unregulated Class A/B power supply
~ 22-9/16"W x 2-5/8"H x 10-1/4"D
350W Peak Power
70W RMS
Wave Guide
Kicker KX650.4:
