best way to make the sub not move?
yea i know.. i have used some L clamps but didnt work..also thought about doing a custom side box but too much $$.. anymore help!!!!
L brackets in the floor SHOULD work fine. Put some velcro on the bottom and it would help a little prolly. Also if you can get the box up against a wall of the trunk/cab that will brace it a little more too. Just make sure when drilling into your floor you dont hit the gas tank or anything else important under the car.
There is no way in hell L brackets could break from driving unless they were extremely thin or they were not connected well to something. Doing what I said will keep if from moving around if you do it right. If you can bolt it straight to the car, do that.
they were thin.. they dont look very heavy duty type so. but i am going to go to home depot and get me some big *** head duty ones!. any other recommendation?>
velcro, tie down straps, thru-bolts on the box, fill the other area around the back of your vehicle with crap so theres no room to move, disgusting amount of duct tape...
implayaz9
implayaz9
LA
Supergumby5000
michigan born
    May 14, 2026
michigan born
    May 14, 2026
