best possible wood
You can use a thinner wood, and then fiberglass it from the inside for strength without the weight. Definitely use bracing. You may still want to use a 3/4 piece for the actual sub mounting location.
Fiberglass is best for strength in curves, not flat surfaces.
nG
nG
That is what the bracing is for. Besides, 1/4 inch thick fiberglass is harder and stronger than 3/4 inch wood. If you use 3/8 in wood with 3/16 thick fiberglass on top, it will be plenty strong for a normal box. I wouldn't load 6 15's in it though.
cdimic25
cdimic25
PV Audio
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
